Local Time 19:04 24 Oct 2026 Privacy Policy
Forum Index : EV's : extended range electric vehicle
tomqu7
Posted: 05:26pm 12 Jul 2013
some times I drive 300 km to and 300 km back
i need van space so I propose to take out front seat
removes lpg tank in spare tyre placeunder rear
remove petrol tank
and replace with batterys
??? batterys and range ????
inn the usa they are able to extend range by towing a very small trailer with a generator and they have units that can be charged relatively fast from any port
???? size of generator ? could I put my work generator on a small,2 wheel trailer
the american reads the renew magazine from the ata alternative enrgy association
I am just going to subscribe
praxidice
Posted: 07:51pm 17 Aug 2013
  tomqu7 said   some times I drive 300 km to and 300 km back
i need van space
In a perfect world I'd like the same thing. Trouble is that all conversions I've looked at are pretty costly for what they are. Likewise all presently available 'off the showroom floor' EVs are well overpriced, particularly in Australia. Ross Blade did some very nice Hyundai Gets conversions, but how can one possibly justify $50,000 for a Getz !!! My guess is the batteries you'd need for 300k EV range would probably cost $30,000 given the weight / aerodynamics of Hiace style vans. then there is the usable life of the things to consider although there are conflicting reports. That Hilux belong Trevor in Mackay apparently wore out the batteries in 80,000k, however a number of cabbies have advised that Prius batteries are lasting more than 800,000k (which must involve an impossible number of charge / discharge cycles). Could it be that the Hilux ones were run down a lot more than bog-standard Prius ones ??
