Forum Index : Site News : New page, blade materials compared
Ron Lin from the web site Windy Nation has sent in a article on his thoughts about using different blade materials. Some of you may be familiar with Windy Nation as a supplier of windmill parts. http://www.thebackshed.com/windmill/articles/WindyNationBlad eMaterial.asp You can also find a link to his article from the Contents page. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| GWatPE Senior Member Joined: 01/09/2006 Location: AustraliaPosts: 2127 |
I would have thought some mention of carbon fibre might have been on the cards. Lakota, and the larger Whisper blades are carbon fibre. I rate them similar to wood, without the maintenance. Gordon. become more energy aware |
| Gary Newbie Joined: 02/04/2010 Location: United StatesPosts: 14 |
Hello, I would like some of your guys input.What do you guys think building your own generator or using a PMA motor? I do understand that a PMA motor is going to require some attention as the brushes and bearings ware out and so fourth. I bought Hugh Piggott's book: A wind turbine recipe Book. He has alot of info and illustrations in his book. Thanks Gary Gary2010 |
Gary, Best you pick the right section to post your message in next time as i dont see this as "site News" more like a windmill question. Please try to use the relevant topic areas. Pete. Sometimes it just works |
