Forum Index : Other Stuff : monster neo’s
| govertical Guru Joined: 11/12/2008 Location: United StatesPosts: 383 |
hi, I purchased two 3 by 2 inch neo magnets. I am planning to fabricate a strong solenoid motor. https://youtu.be/3nmaBrnycJY just because your a GURU or forum administer does not mean your always correct :) |
https://youtu.be/9bzQyEBcQrU Hi, I completed the solenoid, starting to fabricate crank and flywheel assembly. just because your a GURU or forum administer does not mean your always correct :) |
As I've said in the past, I dont want this sort of contraption on this forum, unless you actually get it working first. I do wish you would take advise offered and go and talk to a science professor or teacher about this, so you can move on and use your brilliant prototyping skills on ideas that will actually work. You can not generate endless energy from magnets, gravity or flywheels. You must put energy in to get energy out, and you will always get less out than you put in. Its that simple. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
