Local Time 23:47 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : F&P 3 Phase power
Rastus
Posted: 05:43am 24 Jun 2014
Hello to all members,
I thought I'd test the waters to gauge how viable generating 3 phase power with F&P motors could be. Usefull industrial machines that run on 3 phase power are fairly plentiful and relatively cheap at the moment. I don't want to outlay capital to install 3 Phase to my property and only use it occasionally. I have a couple of petrol engines laying around and a number of F&P motors. Reportedly F&P, in there original wiring state produce 400V 3 phase power with 3-4 amps output. If these were run at 3,000rpm I'm guessing I'd have 50hz. Some questions are, is the 400V 3-4 amp figure from a 100 series F&P? Or later motors? If yes, would it be necessary to rewire later series F&P to 1mm copper? Is it possible to increase the Voltage to 415V?
Any help appreciated!Kind regards Rastus
see Rastus graduate advise generously
Posted: 12:39pm 24 Jun 2014
Hi Rastus
A typical AC generator head has 2 poles per phase to produce 50Hz AC at 3000rpm ( I'm guessing here, its early and my brain isn't warm enough to do the maths. ).
A F&P has 14 poles per phase ( 42 total ). So at 3000rpm the output frequency would be like 350Hz ( Again, a guess, not doing the maths ). This is way to high to run anything designed for 50Hz AC. Also a F&P at 3000rpm would be making some seriously dangerous voltages, likely over 1000v.
If you slow down the F&P enough to get 50Hz, around 428 rpm, the output voltage would be somewhere between 100 and 200 volts, to low for 3 phase AC gear.
Posted: 08:21pm 24 Jun 2014
There are videos on YouTube of people putting F&P smartdrive motors on petrol engines, and the output they produce voltage-wise is extremely dangerous. Taking Glen's example, and assuming an output of at least three to four amps @ 1000v = dead.
It is actually remarkable, what those old smartdrive motors are capable of doing....
I have one here I was always gonna rewire as per the instructions elsewhere on The Back Shed, but have never got around to it.
Rastus
Posted: 04:43am 25 Jun 2014
Thanks Glenn and Grogster,food for thought. Kind regards Rastus
yahoo2
Posted: 09:53pm 25 Jun 2014
for smaller gear a variable frequency drive (VFD) would be more appropriate.
someone like Automation Direct sell them.
A lot more flexible than a rotary convertor or generator. This guy explains it better than I can. VFD drives jeffs youtube
Posted: 10:21pm 25 Jun 2014
=== POST DELETED ===
(realised OP was talking about using SD motor for 3-phase power, NOT generation per-se')Edited by Grogster 2014-06-27
Posted: 03:15am 26 Jun 2014
You do realize you can run a 3 phase motor off single phase using a capacitor.
But it will drop the motor power by about 1/3, in many cases this might not be a problem.
Pete.
Rastus
Posted: 04:42am 26 Jun 2014
Hi Pete,
17yrs ago I rewired a 3 phase 5hp shaper to single phase. Yes it works, a mate of mine still has the machine, however the machine was under powered and it is necessary to slip the drive a number of times to get it working under load, otherwise it would just stall. To overcome that problem run caps were needed and the cost for them was more than a single phase 5hp motor. So the experience has left me lack lust on the results.
Hi Yahoo2,
I was hoping to here from you. I'm aware of other 3 phase options, however I'm being a cheap skate, trying to use what I have. You probably know that my mind hasn't been on this kind of project for a while, so rather than do a ton of research to start with for a dead end result, I thought I'd run it past the brains trust first. I'm not put of yet, but I'll be giving it a lot more thought until I'm convinced it's a waist of time plus Ill learn a lot along the way. Kind regards Rastus
