Local Time 23:47 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : GPS
dwyer
Posted: 08:38am 27 Nov 2013
GPS
That fitted on any motor vehicles and wanted information about How GPS alert the warning on some of fixed speed cameras and red light camera work but l aware will not work on any police speed camera however will work on Radar detector due different setup.
Dwyer
Tinker
Posted: 03:15am 28 Nov 2013
????? Your message is not clear to me.
As I understand it, a GPS is a passive device. It receives satellite timing information and uses the time difference of at least 3 satellites to calculate your global position.
One can link this info to some mobile telephones which then can transmit where the GPS unit is located at any instant.
Or are you asking with regard to the little voice in your 'in car navigator' that says: red light camera 250m ahead? That info is pre programmed to the street data you downloaded from the net.
Klaus
