Local Time 23:21 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : US plug in Australia
Georgen
Posted: 07:15pm 10 Jun 2013
Not sure what to make of it, but was called to be silly because I am looking
for US socket to Australia plug adaptor.
Fellow told me that all he does is slightly twists plug pins changing from
US parallel to Australian angled configuration,
and the only thing to look for is wattage to be 220V not 110V
Sounds fair enough if it can be done this way.
Does anybody have any experience with this issue?
George
powerednut
Posted: 09:05pm 10 Jun 2013
Depends what it is. The switchmode charger that came with my tablet is a multi-country system, so it can take 110V, or 220V, or whatever inbetween. It also came with a number of clip on adapters to suit the power plug of the country, but you can buy adapters at pretty much any travel/camping store or dick smith (if you don't mind paying through the nose) or jaycar. Most rely on the device being capable of running on either voltage.
Posted: 02:51am 11 Jun 2013
I just twist the pins slightly with the plies, works well for me and i have been doing it for years.
Also much neater than using ugly power adaptor gender changer plugs.
Pete.
Georgen
Posted: 06:09pm 11 Jun 2013
Thanks for help.
Looks that fellow was 100% right.
Since plug is melted on the cable I was going to cut it and replace with Australian plug, as adaptors hardly ever sell under $7.
Slightly twisting pins sounds like the cheapest option.
George
