Local Time 23:07 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : Magnetic compass
Posted: 05:57pm 02 Jan 2013
Here is a trick question for you clever people to ponder over, and see if you can give an answer to it without checking the internet first. NO CHEATING.
If the North (red) end of a compass points to Earths magnetic North pole, then when you bring a compass near to a permanent magnet will the compass red end point to the north or south pole of the permanent magnet. And Why do you think this answer is correct?
Pete.
Posted: 06:56pm 02 Jan 2013
The north pointing end of the compass needle must be a south pole, so its attracted to the Earths North pole.
So if you brough it near a North pole of a magnet, it should point to it.
But I bet this is a trick question, and I'm wrong.
Posted: 06:58pm 02 Jan 2013
"Glen wonders if the North pole of the Earth is actually a South pole, but its called North. A bit like electroncs flow from negative to positive, and not the other way around as expected."
Posted: 08:47pm 02 Jan 2013
  Quote  But I bet this is a trick question, and I'm wrong.
No its not a trick question, just something myself and someone had different points of view on, so was wondering what other people thought before checking for an answer.
Glenn, i think you looked it up??
If you must look it up before giving you thoughts to the question, then here is one place to start.
http://www.windows2universe.org/physical_science/magnetism/b ar_magnet_interactive.html
Try moving the compass around the magnet in the link.
It also poses a question to the effects of magnets in our way of thinking to how things are effected by our planet.
Glenn must be the only clever person here to be the only one to comment.
Pete.Edited by Downwind 2013-01-04
MOBI
Posted: 01:11am 03 Jan 2013
  downwind said  No its not a trick question, just something myself and someone had different points of view on
Ok, I'm the someone and I always believed that the earth's north pole was magnetically north too. Well bugger me, a bit of web surfing and the trusty paper version of wikipedia and the north pole is actually south.
No wonder I've been going in circles all these years.
David M.
yahoo2
Posted: 01:38am 03 Jan 2013
Legend has it that Hans Orsted was giving a lecture at the Copenhagen uni, got a bit excited and carried away in the moment and decided to try an experiment mid lecture. He placed a compass alongside a wire that he passed a current through and demonstrated a deflection of the compass needle. Modern historical accounts recall that he was "surprised" when swapping the wires on the battery caused a rapid deflection in the opposite direction.
Isaac Asimov maintained in one of his essays on science that "surprised" is an example of massive Danish understatement, stunned and speechless would be closer to the mark.
I like to think that this was the moment that sealed the electrons fate, to spend the rest of human history running backwards, on the direction a compass pointed, in a uni lecture gone wrong. Or the boffins could have just flipped a coin to decide, while they were blowin the froth off a pilsner or two after a hard day at the lab.
If you are looking for "cat amongst the pigeons" statements, have a go at this one from QI series 1, start of episode 10
Steven Fry:
  Quote  And I go like a belt-fed mortar.
Now, the rules are simple: Points are given, and points are taken away. They're taken away for answers that are both obvious and wrong, and they're given not so much for being correct as for being interesting. Their level of interestingness is impartially determined by a demographically-selected customer service focus consultancy, broken down by age and sex. . . . i.e., me. Erm . . . because there is no one more broken down by age and sex than me.
So. "Aviation", ladies and gentlemen. In the words of, er, John F. Kennedy, "All men can fly, but sadly, in only one direction." For those of you who are nervous of flying, here's something quite interesting. Nobody really understands why aircraft stay up in the air. There are five leading rival theories of aerodynamics, none of which precisely agrees with any other. Fortunately, it doesn't really matter. Automatic control systems on modern airliners are so sophisticated, it's said that by the year 2010, today's flight deck crew of three will be replaced by a single human pilot and a dog. The job of the pilot will be to feed the dog. The dog is there to bite the pilot if he tries to touch anything.
So, fingers on the buzzers, please, to start this round on "air travel". So. Who invented the aeroplane?
Five theories... I always maintained there was three, until some kid invented the remote control micro-copter a couple of years ago, that pretty much stuffed everything.
Posted: 11:31am 03 Jan 2013
So I'm wrong then. If the Earths north pole is magnetically a south pole, then the red end of the compass needle must be a north pole.
So early scientists got the electron flow wrong, and the Earths magnetic poles wrong too, so maybe they got the orientation of the Earth wrong too, and Australia should be Up Over instead of Down Under.
I have to say I'm a fan of QI, best educational show on TV.
Posted: 04:37pm 03 Jan 2013
Glenn,
Best to get the Wrong's out the way early in the year, to save them cropping up latter on more important things.
Truth be known i think 99% of people would have thought the North pole was a north magnetic field and vise versa for the south pole.
In actual fact the earth is made up of 4 magnetic poles N-S-N-S with a N-S in the centre core.
With this in mind do that effect things closer to the equator then nearer to the poles.
  Quote  so maybe they got the orientation of the Earth wrong too, and Australia should be Up Over instead of Down Under.
I think we all in OZ already know we are on top of the world (but Shhhh, dont tell the Americans) the old saying ... cream will rise to the top, is true.
America is closer to the North pole then us, but what they dont realise is the magnetic South charge is dragging their econnomy South.
Pete.
MOBI
Posted: 05:01pm 03 Jan 2013
  Quote  America is closer to the North pole then us, but what they dont realise is the magnetic South charge is dragging their econnomy South.
Geez Pete, you're stirring the possum there.
David M.
Posted: 07:35pm 03 Jan 2013
  Quote  Geez Pete, you're stirring the possum there.
Not sure if the USA has possum's, rattling the squirrel cage maybe
