Local Time 22:55 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : Wire sizes chart
muddy0409
Posted: 11:33pm 11 Dec 2012
Hi all,
I have just spent many hours, unsuccessfully, trying to find a chart to convert Australian wire sizes to AWG.
Can anyone help with the AWG equivelants to the following
7/0.20
14/0.20
24/0.20
32/0.20
40/0.20
Or can anyone point me at a chart that will tell me.
Thanks in advance.Edited by muddy0409 2012-12-13
Don't poo poo conspiracy theories.
Remember that everything ever discovered started somewhere as a theory.
Barry T Coles
Posted: 01:24am 12 Dec 2012
Hi Muddy
Give these a try.
http://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html
http://www.simetric.co.uk/siwire_elect.htm
Or try typing into your search engine "convert electrical wire to AWG" that brought up a heap of sites.
Barry
I need to learn from the mistakes of others.
I dont have the time to make them all myself.
Warpspeed
Posted: 12:35pm 12 Dec 2012
This is a bit tricky, because most common wire charts only refer to converting single stranded wire.
But anyhow, starting with a single 0.2mm squared strand.
The diameter of that would be 0.5048mm or very close to 0.02 inches diameter = 20 thou.
Converting that area to circular mils 20 x 20 = 400
(one circular mill is the area of one round conductor .001 inches diameter)
7 strands 7 x 400 = 2,800 circular mils
14 strands 14 x 400 = 5,600 circular mils
24 strands 24 x 400 = 9,600 circular mils
32 strands 32 x 400 = 12,800 circular mils
40 strands 40 x 400 = 16,000 circular mills
Now to convert circular mils to the closest AWG, you can use this table:
http://www.schaltbau-gmbh.com/en/Products/Connectors/Electri cal-Wire-Conversion-Table/Edited by Warpspeed 2012-12-13
Cheers,  Tony.
