Local Time 22:40 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : Transit of Venus
Posted: 02:54pm 05 Jun 2012
I didn't want to miss the transit of Venus over the Sun, and was hoping to get a photo or two. I did see the last transit in 2004, and used a pinhole projector, but it didn't photograph very well.
Read a few "viewing tip's" on the internet, and some sites suggested you can look at the sun using a welding filter of 14 or more. The highest I could find was a 13, so ended up buying that, plus a 5 and 9, I needed a new filter for my welding helmet anyway. At home on the day before the transit I experimented with the filters. The 13 was too bright, but the 9 and 5 together was OK to look through. I later read this method was only suitable for eclipses, in a transit the planet is too small to see clearly.
Plan 2.
I have a cheap telescope, and rigged up a projection panel with some wire, cardboard and white paper.
Then aimed it at the sun, which takes a bit of work to get steady, plus your movements are backwards.
Once focused, its amazing how much you can see. Sun spots are clear, and Venus stands out. Convincing the camera to auto focus and get its aperture right was a challenge, but I ended up getting a few pictures that I was happy with.
The transit of Venus is a important event for Australia. If it wasn't for James Cooks scientific mission to record the transit, and then search for the great southern continent, we would now be a French speaking nation!
Edited by Gizmo 2012-06-07
Georgen
Posted: 01:02am 06 Jun 2012
Roughly 105 years for another one.
But must say I wasn't overly excited with what I've seen (on the news)
just got bit sad.
George
Posted: 02:40am 06 Jun 2012
Well it's not much to look at, just a little black dot creeping its way across a big white disc. And I know many people will see it as just that.
But I like to think today there were thousands of parents and kids out side, away from the idiot boxes, doing real science in the field. We need that.
Georgen
Posted: 04:05pm 06 Jun 2012
[quote]
just got bit sad.
[/quote]
Have to explain myself, I got sad for different reason, not that it is insignificant
but because when I think about it I am overwhelmed with :
Vastness
Entophy inevitability (back to nothingness NO MATTER WHAT)
Of course not in my lifetime …
George
Posted: 04:22pm 06 Jun 2012
Ah I see, that makes sense. Yes when you see this little black dot, and realise its a planet about the same size as Earth, makes you appreciate the size and power of the Sun.
imsmooth
Posted: 06:12pm 30 Jun 2012
I watched almost the whole event on the Webcast. The sky was completely overcast where I live. Maybe in a 105 years it will be clearer. I have some interesting math deriving the distance calculations.
