Local Time 20:24 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : Trevs stuff
Col Dixon
Posted: 06:15am 29 Oct 2009
hi Trev i have just regoed to home grown
iam col dixon
the home grown power website even works well on dialup snail band.
i was blown away with your diary trev
You are doing what i dream about.
Your work is so good your machining of parts are made from a craftmans hands how do you find the time?
your mind of knownlege of electric power is awsome
you are doing what i would luv learn about.
keep up the great work Trev ..col
shaky
Trev
Posted: 09:40am 01 Nov 2009
Col,
Welcome to the Forum. Thanks for the comments.
The reality is, I don't know much at all. There are other forum members here that are my role models. But then I guess if I knew everything, it would become boring. I am just Hav'n Fun.
All it's about is, 'think about it, and have a go'.
Anyone can do what I do.
Time...well....
Read up on the forum, you will learn heaps of stuff. Someday Col, you will have made a wind generator and... that you will be proud to show off.
Trev @ drivebynature.com
Col Dixon
Posted: 08:14am 04 Nov 2009
Hi Trev
its col
Thanks so much for your reply on my rego.
Iam working on a vawt type w/mill made from 2 plastic 205 l drums cut in half lenght ways .
It turns in the lightest of breeze .In a strong wind a few weeks back I put f&p magnet drum with the stator inside and placed the o.d of the drum up against the wheel barrow at the bottom of the w/mill shaft and with the standard wiring .I measured 30 volts from 1 phase
i was rapped now learn how 7 phase it and declog the stator thanks again Trev the Master Craftman .
shaky
KarlJ
Posted: 09:30am 07 Dec 2009
Hey col
playing with entirely unmodified stators can be dangerous, they will make 300+ volts.
Keep fingers well away when taking any measurements!!
more than a few of us have had a bite or two!!
Karl
Col Dixon
Posted: 08:58am 16 Dec 2009
Hi Karl
thankyou so much for your reply about my f&p vawt w/mill.
your advice about the bities Is duly noted and your advice is very much appreciatated .
You guys are tops that includes allthe other backshed guys out there playing and having fun
All you guys are inspiration to me . and you are fart smellers ie smart fellows
thankyou so much again Karl
shaky
