Forum Index : Other Stuff : Concentrated Solar Thermal
42pole
Posted: 06:47am 27 Aug 2009
Hi all, I am new here and can see that you are all well versed in the nature of clean energy.
It has been my obsession for a number of years and I have looked into several viable methods to tap this renewable source of energy.
Recently I obtained a WW2 searchlight parabolic mirror(1.2m dia) and found that the focal point (120mm dia) exhibits some 600 degrees centigrade of usable energy. I was thinking of using a stirling or steam engine coupled with a modified F&P assembly.
I would appreciate any input on this or indeed any other means of converting heat to electricity. Maybe peltier/ seebeck or thermal diodes. Any thoughts?
GWatPE
Posted: 07:06am 27 Aug 2009
Before U start on the engine, U need to perfect the solar tracking system. The focal point is very precise.
Gordon.
become more energy aware
42pole
Posted: 07:59am 27 Aug 2009
Thanks for your response Gordon. I have erected the mirror onto a gimbal assembly and have begun building a sun tracking servo assembly using small 24volt geared motors driven by a photo-transistor tracker aligned with the focal point. My problem now is to find the most productive method of efficiently converting the energy into something storable. Steam is the most obvious as it is easy to produce and has the ability to run an engine as well as being condensed for storage as hot water, but a passive system may be advantageous for noise limitations as I live in suburbia.
Posted: 08:57am 27 Aug 2009
Sounds like fun.
You are capturing about 1 square meter of sunlight, Dependng on where you are, but in Australia during summer on a clear day thats approx 1000 watts.
A stirling cycle engine is roughly 20% efficient, so you'll get 200 watts shaft power in full sun. A good alternator at 75% efficient will give you 150 watts electrical power.
150 watts is OK. If you can build it a lot cheaper than 150 watts of solar cells, then it might be worth considering. Remember there will be a lot of moving parts to maintain.
What about using peltier with a big heatsink on the cold side? Not as efficient, but no moving parts, apart from the tracker.
42pole
Posted: 12:11pm 27 Aug 2009
I knew I could find some help here, thanks for the input Glenn.
The maintenance of such a rig is unavoidable, but the trade offs are worthy of exploration. As you noted, the efficiency of peltier is very poor, but I believe high temperature differential devices exist which are suited to extreme temperatures.here
I read somewhere there is a new thermal diode array that promises much improved efficiency (>40% ideal Carnot cycle). Unfortunately they are still in the development stage.
Lou
MacGyver
Posted: 05:47pm 28 Aug 2009
Might I suggest an easier method?
Being parabolic in nature, your mirror has a somewhat "exact" focal point.
You need to maximize this feature to grab all the power it can
concentrate. To do this, the sun's rays must enter parallel to the focal
axis, which is at ninety degrees to the mirror plane prescribed by the
mirror's circumfrence.
An easier method would be to mount the mirror in a STATIONARY
position and use a flat-plate heliostat (mirror) to reflect the ever-
changing sunlight onto it. This way, the rays of sunlight all enter at
ninety degrees to the plane of the mirror.
Maneuvering a lightweight flat mirror will be way easier than trying to
move a gimbaled heavy curved glass one.
A flat-plate mirror will be easier to mount, clean and control than using
that heavy paraboloid monster. The curved mirror could be placed into a
'house' or some other structure that would allow you to mount louvers
that could be used to control the amount of sunlight entering the
mechanism. This would allow you to refine its focus, if the individual
mirror pieces are moveable.
I've done this on a smaller scale to manufacture steam to run my steam
engines. The easiest method to create steam is to pass water through a
coil at the focal point. I used oil and stored it in a buried (in beach sand)
tank to enable longer steam runs for my toys. I used the hot oil in a heat
exchanger (boiler) and pumped in atomized water (fine spray).
If you make steam, use distilled or R/O water or you'll plug things up in
no time at all (dissolved calcium in the water).
The question will arise that you are wasting some of the energy by
reflecting it off the first mirror. This much is true, but since it's all FREE
stuff (sunlight) who cares?
Copeville, Texas
42pole
Posted: 12:23am 29 Aug 2009
Now that's thinking outside the square. You're right as to the monster (40kgs) being difficult to accurately maneuver and my current rig is somewhat 'Heath Robinson' in design.
You noted impurities in tap water clogging the works, I didn't think of these implications in my design..thanks for the heads up MacGyver. You were always credited with lateral thinking.
The enclosure design is also clever, cage the monster and controlled feeding will keep him regular.
Is it possible to use a convex, thereby smaller heliostat or do the convergence losses outweight any control benefits? Also what is the percentage losses in current mirror designs? I know that the accurate mirrors used in laser technology are 99% reflective, but the doping process would be expensive for a larger flat plate reflector.
MacGyver
Posted: 03:27am 02 Sep 2009
My advise would be to keep it simple.
I use a portion of a mirrored glass wardrobe door cut to size. It's still
pretty heavy, but not to the extent that it can't be maneuvered easily. An
advantage to this is it has a form-fit extruded aluminum border on each
side. If you try to go fancy and use a convex, it will throw UN-parallel
lines of light at your curved mirror and you'll wind up with zero.
As far as % efficient, I don't give that a second thought. If I determine it's
not efficient enough, I just make things BIGGER!
By the way, as long as we're talking about percentages, about 90% of my
building materials come from dumpster diving.
When a cop sees a kid in a dumpster, he gives him hell and runs him off.
When a cop sees me in a dumpster, he probably thinks I have some
business there and leaves me alone. That's an advantage to being 60 and
resembling "Gandalf".
By the way, that "cage" besides being a way to control the light input, is
really important if you have kids around. Think for a minute what would
happen if a kid put his hand at the focal length while his buddy fiddled
with the heliostat!
Copeville, Texas
