zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 702
Posted: 11:22pm 17 Mar 2025
Ages ago I got a little T8 CNC. Finally getting to try something useful with it, using bits of grbl. It is running OK mostly, needs reset after spindle starts so I will have to look at cleaning up the power supply sometime.
The cutter supplied looks like a thin wedge of carbide. Using it is fine for a shallow cut is fine but the cut metal edge is a bit ragged and has to be cleaned up. The material is thin laminate 3mm, two Al sheets with HDPE between.
A rookie question, how do you get sharp cuts ? Would a different cutting bit be worth the expense ? Edited 2025-03-18 09:22 by zeitfest
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3416
Posted: 12:04am 18 Mar 2025
Some possibilities:- a) Reduce the feed rate. b) Multiple passes, a shallow cut first then incrementally deeper till you get the required width. c) Multiple passes, shallow cuts side by side. If depth isn't important and you just want to cut through the aluminium.
