Local Time 19:32 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : Gearing and power output.
Davo99
Posted: 10:27am 18 Mar 2024
One for the mechanical engineers.....
I have tried googling this question but no matter how I phrase it , I always get irrelevant answer's to what I think should be straightforward for those in the know.
I found a Diesel engine today up the back I forgot I even had.
It's 10 HP continuous @ 2400 RPM.
I have an 8 KW gen head which is 1500 RPM.
My belief is it takes double the engine HP to drive an alternator / Generator for every KW the alternator is. Going by this rule of thumb, the engine does not have the power to drive the gen head to full load.
My question is if I reduce the driven speed of the engine output with the appropriate size pulleys and have the engine doing 2400 rpm and the alternator geared down to 1500 rpm, will the effective power the alternator sees be increased say to 12 or whatever HP it works out to be?
As I understand, power is function of torque Vs. Speed but I do not know how this applies in this case. I would think that at the given speed, the alternator needs increased torque as the speed needs to be fixed so the answer should be Yes, the engine will have more effective power or if that is not the right term, Gearing the faster engine to the slower alternator will in fact increase it's ability to drive a higher load on the alternator at a fixed RPM.
Can anyone confirm that gearing the engine down will effectivel increase its HP at the lower RPM the alt would see?
Thanks in advance.
Posted: 11:22am 18 Mar 2024
Power = Rotation Speed x Torque
Units:-
Power - Watts
Rotation Speed - Radians / Second (Rad/S = RPM x 2 x π / 60)
Torque - Metre-Newtons (9.8 Newtons = 1kg force)
When you gear the speed down the torque is geared up by the same proportion so the power remains unchanged - ignoring losses.
Getting more power requires more fuel. Fuel and air are the only inputs to the system, everything else consumes power.
Davo99
Posted: 12:10pm 18 Mar 2024
OK, so in this instance with the faster engine and the slower generator, would I be able to put more effective load on the generator than the engines rating or not?
If the engine is 10 HP and it's 2 HP per kw, that should at engine rating allow me to generate 5KW out of the alt.
By gearing the speed of the engine down, am I going to be able to get more than 5 KW out of that same engine due to the multiplication of the touque?
Posted: 09:06pm 18 Mar 2024
The power is produced by burning the fuel. You can't get more out than you put in.
  Quote  By gearing the speed of the engine down, am I going to be able to get more than 5 KW out of that same engine due to the multiplication of the torque?
Again
Reducing the speed reduces the power by the same amount that increasing the torque increases it.
Only with magic can you get more out than you put in.
Revlac
Posted: 09:29am 22 Mar 2024
Found a handy tool. https://www.blocklayer.com/pulley-belt
Cheers Aaron
Off The Grid
jeffj
Posted: 06:35am 01 Jun 2024
The diesel will supply 10 hp  at 2400 rpm   1 hp =746 watts so at 2400 rpm you should get 7.46 kw at the shaft
The generator is rated  at 8 kw at 1500 rpm so you will need to reduce the speed of the diesel to 1500 rpm with belts. The belts will absorb a bit of the power
The other consideration is the frequency of the  generator which is proportional to the speed.
