zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 702
Posted: 12:12am 05 Jan 2022
There is a "battery rejuvenator" liquid sold at the outlets, it is a small bottle with (I think) a solution of cadmium (nitrate?). Anyone tried or used it ? Maybe it helps reactivate sulphated plates ??
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3416
Posted: 03:23am 05 Jan 2022
Unless this is a new type of rejuvenator backed up by impartial testing be cautious. Long ago the place I worked at, having lots of battery backup systems tested the ones available then and found they all shortened the life of the batteries. Lead acid batteries are topped up with distilled water for a reason. Foreign chemicals can interfere with the reversibility of the plate reactions. What the additives can do is disrupt the hard sulphate crust that can form on the plates. This crust raises the internal resistance, chemically removing it restores cranking capacity at the expense of declining AH capacity. Cycling the battery a number of times at a rate specified by the manufacturer, though not perfect may be better. Edited 2022-01-05 15:26 by phil99
