Local Time 22:01 24 Oct 2026 Privacy Policy
Forum Index : Solar : Solar Help
rustyrod
Posted: 03:30pm 24 May 2017
I have two 90 watt solar panels in parralell for a 12 volt system.
Recently I noticed that they have stopped working.
However if I short the wires together for a moment or connect a 50 watt bulb across them, then after 15 to 20 seconds the panels start to work.
I must do this procedure every day between 9 and 10 am to get them up and working.
They have good output until sundown.
I have developed a major back problem and cannot walk let alone get up on the roof.
Is there anyone near Toowoomba in Qld who may be generous enough to come and have a go at them for me, Please?
Coffee will be supplied.
Always Thinking
Boppa
Posted: 09:22pm 24 May 2017
I'm heading down to nsw to rego my sisters car tomorrow, but probably back Sat (if it doesnt need repairs), if noone else has a chance before I get back, be happy to lend a hand (only about 20 min away)
rustyrod
Posted: 09:50pm 24 May 2017
Thanks, I have PM you
Always Thinking
yahoo2
Posted: 09:39pm 25 May 2017
sounds like a classic dry jointed connection.
the other thing it might be is water inside the cable, I see it a lot with satellite cables, a parrot will take a little nip at the outer sheath up on the roof and the water will run down and fill up the cable inside then the DC will rust the core away.
