Local Time 22:35 24 Oct 2026 Privacy Policy
Forum Index : Solar : solar panel shattered
charlie_ruizpr
Posted: 05:12am 29 Feb 2016
Hi, I recently acquired from a friend a suntech 175watt solar panel that was dropped but working, the only thing is that the glass shattered, is there a way to seal that glass or replace it?
Posted: 12:09pm 29 Feb 2016
My suggestion would be to buy a sheet of glass that fits over the old, inside the edge. Leave the broken panel in the sun for a few hours to get any moisture out of the cracks, then put a few blobs of clear neutral cure silicon evenly over the panel, place the new glass on top and let it cure for a few days so the gasses can vent, then seal the glass edge with more silicon. That way you get the strength back and keep moisture out. Moisture is the killer.
charlie_ruizpr
Posted: 12:44pm 29 Feb 2016
thank alot
KarlJ
Posted: 02:48am 05 Mar 2016
got 2nd hand "unbroken" `180W panels at most Solargain branches across Australia
typically ~$80 a pop.
Malaga (the biggest branch) has half a dozen Kyocera 48cell modules (185W) at just a carton of beer a pop. (minor delaminations of the backsheets) still working AOK.
Sunpower 210's at $150 each SANYO 205's at $140 each both AWESOME panels (up there with new tech)
K
