Local Time 22:38 24 Oct 2026 Privacy Policy
Forum Index : Solar : Solar Hot Water
rustyrod
Posted: 05:29pm 19 Jan 2016
I downloaded THIS and started reading.
I am blown away.
CAUTION: THIS WATER HEATER IS ONLY INTENDED TO BE OPERATED BY PERSONS WHO
HAVE THE EXPERIENCE OR THE KNOWLEDGE AND THE CAPABILITIES TO DO SO.
THIS WATER HEATER IS NOT INTENDED TO BE OPERATED BY PERSONS WITH REDUCED
PHYSICAL, SENSORY OR MENTAL CAPABILITIES I.E. THE INFIRM AND CHILDREN.
CHILDREN SHOULD BE SUPERVISED TO ENSURE THEY DO NOT INTERFERE WITH THE
WATER HEATER
THEN
Period Of Reduced Usage Or Holidays
WARNING: IF THE WATER HEATER IS LEFT UNUSED FOR TWO WEEKS OR MORE,
FLAMMABLE HYDROGEN GAS MAY ACCUMULATE IN THE WATER CYLINDER.
To dissipate this gas safely, it is recommended that a sink hot tap be turned on for several minutes. Do not use a
dishwasher, clothes washer or other appliance for this purpose. During this procedure there must be no smoking, open
flames or any electrical appliance operating nearby. If hydrogen is discharged through the tap it will make an unusual sound
like air escaping.
(HYDROGEN did they say HYDROGEN ??????????????
AND wait there's more)
Hartgard’ Solution – Freeze Protection
Solahart Closed Circuit Systems are protected against freezing or harsh water conditions by our exclusive „Hartgard‟ fluid.
„Hartgard‟ is a blue, non-toxic, propylene glycol fluid which, when mixed with water, provides the Heat Transfer Fluid
contained in the solar collectors and the heat exchanger jacket around the tank. „Hartgard‟ is used to lower the freezing
temperature of the Heat Transfer Fluid and so provides protection against freezing (Note: for the correct % of Hartgard in
the Heat Transfer Fluid, refer to the section on Frost / Freeze Protection). „Hartgard‟ is a special food grade solution and is
the only solution permitted to be used in the closed circuit systems. Hartgard has been approved by the National Health and
Medical Research Council of Australia.
WARNING: SHOULD THE WATER FROM YOUR CLOSED CIRCUIT SERIES WATER HEATER
APPEAR BLUE, THEN THIS MAY INDICATE A LEAK OF „HARTGARD‟ FROM THE HEAT
EXCHANGE JACKET INTO THE POTABLE WATER.
Although ‘Hartgard‟ is of food-grade quality and not hazardous to health, the blue colour in the water does indicate a fault
and your Solahart dealer should be contacted to inspect the system.
unquote.
I have heard "Hartgard" is expensive so some systems have been filled with automotive radiator additive.
Just what you need in your drinking water.
Always Thinking
Georgen
Posted: 10:45am 21 Jan 2016
It looks similar to what you read in medicine's side effects leaflet.
All possible problems are listed to reduce risk of litigation.
George
VK6MRG
Posted: 05:19pm 21 Jan 2016
Standard legal jargon.
I have seen it before on some electronic components and equipment.
MacGyver
Posted: 08:54am 13 Jun 2016
Rustyrod
I'm a retired plumbing contractor of 45 years experience. Sometimes, when a small, stray electric current is allowed to pass through a water heater's sacraficial electrode (usually magnesium-aluminum alloy) it can produce hydrogen gas.
There's no worries about an explosion. It needs oxygen to burn and it only gets oxidized (oxygen) when it emerges from the tap. I have even lighted it with a match at that point. It "pops" a bit, but that's all.
HOWEVER, if you vent a large quantity to a room through a tap, hydrogen, being the second-lightest element just behind helium, the gas will head for the top of the room. If it gets trapped there, accumulates and you provide an ignition source (spark, cigaret spark, lighter, etc.) you will likely blow the roof off your house.
Be careful, but don't lose any sleep over it.
. . . . . MacEdited by MacGyver 2016-06-14
Copeville, Texas
