Local Time 22:38 24 Oct 2026 Privacy Policy
Forum Index : Solar : mppt/solar panel volts to high
rgormley
Posted: 01:23am 04 Mar 2015
i have a problem hoping someone can help with an idea?
have 6 Sharp NU-SOE3E panels
VOc=30v
Vpm=23.7
purchased a 30Amp MPPT charge regulator. GSC-2448
http://eastups.en.alibaba.com/product/318490272-210189250/12 _24_48Vdc_Solar_charger_controller_with_LCD_display_10A_60A_ Type_.html
the problem is the panel volts VOC today was 55 volts (have them 2 in series)
regulator said NOPE not happy, volts to high...
the upper max upper limit from the book is 48V and Working volts 29-38v
what can i do? in series gives me up to 55v on a sunny day and that is to high.
in parallel i`m only going to get 23.7v so it wont feed the MPPT regulator with enough volts...
What to do?
DC-DC voltage converter? expensive...
drop volts over large power diodes? (wasteful?)
Thanks.
davef
Posted: 04:52pm 04 Mar 2015
Just checking ... are you trying to charge 24V batteries?
Your Vpm of 23.7V seems a high for one panel to charge 12V, I think mine is about 17Volts. Were the panels designed for 12V charging?
For my 24V system the charge controller can handle up to 90-100Volts, so an upper limit of 48Volts for a 24Volt controller does seem low.
I would consider putting a dump load (shunt regulator) that kicks in at 45Volts, if you didn't want to buy any controller. Seems a waste unless you could use it to heat water or something. How much current do you have "shunt" to get your panel voltage down to 45Volts, it might not be a lot.
Tracer 30A controller is about $200US from China.
rgormley
Posted: 09:52pm 04 Mar 2015
it is a 24v bank i run.
after lots of playing, yes have come to the same conclusion.... need a better regulator....
now the Ebay/local hunt for a unit..
need a 40Amp unit to be safe....
rgormley
Posted: 09:14am 05 Mar 2015
problem will be solved...
just bought a 40Amp tracer MPPT unit 100Voc input...
KarlJ
Posted: 10:19pm 06 Mar 2015
Ebay or Au seller?
Apolloenergy sells them here is Aus with a proper warranty
vs ebay your mandatory 30 days.
rgormley
Posted: 11:17pm 06 Mar 2015
  KarlJ said   Ebay or Au seller?
$259 vic seller
Although i just spied on the Apollo website 2nd generation unit at $236
Really?? bugger it!!.....
Ps Karl , you installed my orig on grid system (i think?) via energy matters..
rgormley
Posted: 11:25pm 06 Mar 2015
jey Karl, why is the older tracer more expensive than the new generation?
normally the newer stuff is more expensive?
Posted: 03:31am 07 Mar 2015
I would suggest you follow Karl's advice, as he is hands on in the industry, and not a guru due to post content, like many here.
Pete.
Eugeneo
Posted: 08:20pm 13 Apr 2015
Now you can run 3 in series and 2 in parallel and go up to 6 AWG.
rgormley
Posted: 12:26pm 14 Apr 2015
  Eugeneo said   Now you can run 3 in series and 2 in parallel and go up to 6 AWG.
the reg has a spec of 100 v max input (i have the older unit, yes i know the new "imporoved" model does 150V
the VOC on my panels are 30V
3 in series is pushing a little close for my liking (during edge effect?? may push upper limits of 100V on the REG)
i will keep it as is with 2 in series... (around ~60v VOC max)
as a side note, do these MPPT REG`s work better with higher voltages inputs. or is there a sweet spot? voltage wise?
ie: like 4 panels in series (120v) safety/dangerous at these levels though... but as for conversion inside the REG`s how do they fair???
Eugeneo
Posted: 02:15pm 14 Apr 2015
I have used the TriStar MMPT in the past and I would assume they are about the same technology. I really like the TriStar unit because it has a RS485 Modbus slave feature. This allows you to adjust and monitor almost every aspect of the panel without any extra hardware. You can monitor the input power and the output power and see the controller loss.
Inside the MMPT controller generally consists of a buck regulator that does a quick voltage sweep to automatically find where the power is the highest.
P=IV. As the voltage increases you get more power until the current starts dropping off.
On my cells with a 30 VOC it sits at around 26 volts on a sunny day.
If you go with double the voltage on the output of the solar cells, you can literally 1/2 copper area of the wire size and still have less loss. Because P(loss)=I^2xR it's a very big advantage (you are decreasing I).
Also on a cloudy day, the higher the input voltage, the more room the controller has to synch down to create the amps.
The VOC rating is the voltage open circuit so there is very little current at this voltage. As soon as you put any load on it - it will drop fairly quickly to it's higher current rated area. Try to find the cell's data sheet and you will see what I mean. At this point you can decide what is 'safe'
Hope this helps. Good luck!
Edited by Eugeneo 2015-04-16
windy01
Posted: 09:14pm 11 May 2015
Schneider make a great regulator probably better than the Outback Flexmax 80
3Px3S configuration for most modules no problem
