Local Time 23:07 24 Oct 2026 Privacy Policy
Forum Index : Solar : the Piggott of solar water heating
elrastita
Posted: 05:46pm 07 Jun 2013
Hi!!! i bought the book of hugh piggott, "a wind turbine recipe book", i build it and itīs working nicely. i like very much how easy and effective is his design. For shure there are others designs much more efficient, but what i liked most of it, is that his design is simple, robust, works, and was tested and tested and tested....
Now i want to have some hot water, do you know anything similar to "the piggott windmill recip book" but for solar water heating???.
Thanks you very very much!!!!
crez
Posted: 01:52am 21 Jun 2013
Hi
There is lots of good stuff on the builditsolar site. In particular try builditsolar. I found a stack of frost damaged panels at the local scrap yard and have repaired three of them and they heat our spa 3 seasons. In winter they provide about half the heat. I have four more which I plan to set up to pre-heat water entering our electric cylender. Both systems will be drain-back types as described on the website above. Have a look at the "The $1K Solar Water Heating System" section.
David
elrastita
Posted: 05:49am 26 Jun 2013
Thanks you very much!!!! good site!!!
Madness
Posted: 03:15pm 28 Sep 2013
Nice to build your own but if you look around on Ebay and Gumtree you can buy second hand at a good price.
I got a 300 litre rheem that was not pumping, turned out the controller was RS. I built a new controller using an Arduino for well under $50.
Posted: 05:36pm 28 Sep 2013
  Quote   if you look around on Ebay and Gumtree you can buy second hand at a good price
I would think postage might be a killer (Argentina )
