Local Time 22:07 24 Oct 2026 Privacy Policy
Forum Index : Solar : volt meter 4 pararell battery help needed
bobt
Posted: 09:33am 18 Jun 2011
g'day everyone,
recently i decided to
upgrade to a duel battery bank with my small solar setup,
iv been using a single battery up to now,just a 12volt system.
so i brought two new 80amp hour deep cycle batteries.
my question is when the batteries are wired in pararell mode,
which battery terminals do i use to connect
the volt meter to? battery 1 or battery 2,or what?
cheers
bobt
Edited by bobt 2011-06-19
Tinker
Posted: 03:10pm 18 Jun 2011
Bobt, this is something easily tested with a volt meter
By parallel you mean you connected the positive terminals of both batteries together.
You also connected both negative terminals to each other with a separate link strap.
Connecting a volt meter at either battery will show the exact same voltage, they are connected together after all.
Simple, isn't it?
Klaus
