Local Time 21:55 24 Oct 2026 Privacy Policy
Forum Index : Solar : soalr panels mounting rails and bits
rgormley
Posted: 03:30am 15 Mar 2011
Anybody know of a good priced place to get solar panels mounting rails,brackets and so forth. in melbourne (western subs) but i can travel....
will be adding panels to a tiled roof.(or any other sugestion for mounting panels that wont break the bank)
yes, i`m handy with tools
(Karl-J) you must know some people.....
thanks..
Edited by rgormley 2011-03-16
Joblow
Posted: 12:04pm 15 Mar 2011
I would think that the aluminium merchants like Capral, Chinalco etc would keep a variety of sections suitable for mounting solar panels.
The man who never made a mistake never made anything
angelcas
Posted: 04:39am 20 Mar 2011
Hello, I am new to solar panel stuff, is it easy to put a solar panel at home?
Weather Stations For Home
KarlJ
Posted: 10:21am 20 Mar 2011
Unfortunately the game has gotten tricky as technically you should meet a building standard, that aside there are really good reasons for using off the shelf, proper solar panel mounting hardware.
Mostly saves one helluva lot of time, can mount 8-9 panels on a tin roof in under an hour.
doing the same job with aluminium angle means 99% of the time the batton spacings wont match the pre-drilled holes in the panels and you'll need to drill new holes in the panels to match, no biggun but if you make a mistake, a whole row of panels ends up looking drunk and with lots of holes in the frames.
The system I have been using for a while now and can recommend from both an ease of use and cost perspective is the SUNLOCK system.
Available from apolloenergy / energy matters for about $300 / KW retail.
The difference between trade and retail is GST and handling fees so I reckon pretty reasonable.
There are other systems available but there isnt one I've found to be cheaper -without having serious compromises.
They also come with all the bits, nuts bolts, screws where other suppliers you're forced to buy these bits separatly- typically $1 a bolt/washer/nut in stainless.
