Local Time 21:42 24 Oct 2026 Privacy Policy
Forum Index : Solar : SMA SunnyBoy OptiTrac
Adrian@Brisbane
Posted: 02:07am 06 Dec 2010
I have a SMA SunnyBoy 4000TL-20 with the new OptiTrac option. By default it was switched off. I have switched it on to see if this makes any difference in cloud cover. Thoughts? Can't hurt anyway.
Adrian
KarlJ
Posted: 08:40am 11 Dec 2010
what is it supposed to do?
Adrian@Brisbane
Posted: 09:12am 11 Dec 2010
Snipped this from the SMA OptiTrac PDF.
Equipped with SMA OptiTrac, the inverter reacts
much more precisely to changes in radiation levels,
so that the maximum energy available can be
constantly fed into the grid. Thus, SMA OptiTrac
significantly improves the dynamic behavior and
increases the energy yield on intermittently cloudy
days.
http://download.sma.de/smaprosa/dateien/3491/TECHOPTITRAC-AE N082412.pdf
Follow the above link for an interesting read.
Posted: 11:05am 11 Dec 2010
Now that sounds like a wonderful sales spin to me.
In short by changing the interval the system reads the input voltage and adjusts the output to suit increases power into the grid.
Whoopie, you would expect that normally, and one has to ask what is the down side of this function considering it is a user option.
Pete.
KarlJ
Posted: 07:16am 12 Dec 2010
Indeed I laughed, the MPPT tracker on the cheap (but great) CMS2000 is changing the voltage every second and is supposedly 99%+ efficient at doing it the MPPT tracking that is
I would hope SMA are doing it better but 99% is tough to beat
