Local Time 20:50 24 Oct 2026 Privacy Policy
Forum Index : Solar : broken ebay cells
cobo351
Posted: 02:30pm 17 Jan 2010
Going to try soldering some 3x6 inch cells together today. Some are cracked acrossed, some broke in half, and some have small peices missing. Since this is my first time I should learn something. If anyone has any pointers, I'm all ears.
Cory
cobo351
Posted: 03:44am 21 Jan 2010
Soldered 8 out of 40 cells together this past weekend (hope to have 36 good ones when done). Got 4.6 volts total, which is a little better than the .55 volts per cell, advertised on the listing. Does wiring these together add up similar to wiring batteries (parallel increases amps only & series increases the volts only)? Amps per cell advertised on the listing per cell is 3.6
KarlJ
Posted: 04:26am 21 Jan 2010
yep got it in one.
