Forum Index : Solar : good news for Li battery recycling
| poida Guru Joined: 02/02/2017 Location: AustraliaPosts: 1497 |
wronger than a phone book full of wrong phone numbers |
again, it posted when I hit <return> sorry. https://pubs.rsc.org/ee/article/19/13/4199/1260994/Direct-electrode-to-electrode-regeneration-of-end this seems to be a big thing to my mind. end of life Li battery can be "recycled" in a way that makes it good to go without complete degeneration in simple elements. maybe if we now start designing (Li battery) chemistry for this process it could be a big step towards low raw material input R.E. energy storage. I care about this sort of thing, we need something that scales to global dimensions if we will ever get off the FF teat and stop increasing CO2 levels in our one and only atmosphere. wronger than a phone book full of wrong phone numbers |
| Solar Mike Guru Joined: 08/02/2015 Location: New ZealandPosts: 1255 |
As battery chemistries evolve, with now cheaper and more abundant Na compounds being introduced, their main constituents are carbon and aluminum neither being in short supply, along with a little sodium based electrolyte like NaPF6. If Lithium based cells are on the path of an "Old" technology, there may be little incentive in attempting a mass re-cycling program, as the reclaimed material may have little usage. Not sure what's going to happen with the millions of old batteries that will become available in the next 15 years as current ones fail; It's a bit of a worry. |
There is a new recycling plant in Victoria but I think it uses the old method of reducing the cells to granules or powder for further chemical processing. |
| Godoh Guru Joined: 26/09/2020 Location: AustraliaPosts: 712 |
The recycling plant in Victoria is a good thing to hear about Phil. I was wondering where all the mobile phone, and laptop batteries were going to go. pete |
