Forum Index : Solar : Prediction of solar PV output for day(s) ahead.
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 906 |
G'day, I'm seeking views on the prediction of solar PV output for day(s) ahead. (I'm new to this section of TBS, I normally lurk on the Microcontroller and PC projects section.) We have had a new solar system for a few months (14kW of panels, 8kW inverter, 16.6 kWh battery). Last night was the first time we dropped to minimum SoC (set at 15%) and we had to import a fair bit of power. At sunset we only had 90% in the battery - I could have held back on some consumption. That prompted me to Google sites that helped predict solar output based on weather forecasts. The one that caught my eye was 'OpenWeather'. I already use it for weather (current and forecast) as it outputs in JSON - which I can use via my Webmite. Do any of you have any comments or suggestions? Cheers, Andrew |
Revlac![]() Guru Joined: 31/12/2016 Location: AustraliaPosts: 1309 |
I did see https://forecast.solar/ but I think you have one that is probably better, however I don't think this is the total solution for this weather situation, your overnight consumption is high compared to your storage and production, back later.Cheers Aaron Off The Grid |
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2284 |
This might get confusing with a post in both Solar and Micro forums. You likely know that Windy.com has a solar Power index map layer, I believe you can pull data, I normally know how we will go by looking at predicated cloud cover. I have 11kW of panels running at the moment, most are Flat, some South and East facing, only 8 are facing north, in South-East QLD. With my panel configuration I keep single panel shading effects to a minimum and the flat and south panels are very effective in overcast rainy weather, where slope and direction are meaningless. There are 7 solar chargers, one for each 4 panel array, it's raining and completely overcast today, currently solar index indicates 130W/m2, each solar array and charger are producing exactly 3.7A, South, North, East and Flat. 7 x 3.7A = 25.9A @ 53.2v = 1.38kW. The solar index level indicator is real time tracking with the movable readout flag over my location. It's cycling between 92W/m2 and 296W/m2. Power is dropping to 700W under darker cloud cover with heavy rain. I have over twice the battery capacity you have, and with the rain yesterday we are down to 64% SOC (Full electric home and workshop) another day of no real solar and we will be down to around 34%, it looks like the following day (WED) will be brighter with some lighter cloud cover, that should easily get us back to around 70% SOC. We have not used Mains for over a year. I assume you have LiFePO4 batteries and are in a Southern state. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Hi Mike and Aaron, Thanks for your replies. I'm a complete novice on the solar front but have been playing with MMBasic for 10 years. I posted to both forums as I assumed some shedders would have an interest in one field. I know I hadn't been looking at the other forums. We are 5k east of Melbourne, are fully electric with no gas. The house is to Passivhaus standards (heavily insulated, triple glazed and a heat recovery system). It has a 'tin' roof, at 15deg facing north. All the unshaded roof has PV panels with micro-inverters. Yes it is a LiFePO4 battery (BYD). With a full battery at sunset we typically dip to 40% and by playing with the the pool equipment get it back to 100% each day (except yesterday). We are not exporting yet. I'll go looking at Windy.com. Cheers, Andrew |
I just did a test with the site Aaron referred to. It gave good realistic readings for today (mostly sunny) at 10am their 1315W compared to my 1295W I suggest trying the public api for a few weeks to see how it compares with actual before getting to involved. https://doc.forecast.solar/api:estimate Jim edit: for the last two days, actual generated was ~7% lower than the forecast.solar estimate. Early days but looking usable for short time forecasts. Edited 2026-05-20 13:07 by TassyJim VK7JH MMedit |
