Local Time 20:30 24 Oct 2026 Privacy Policy
Forum Index : Solar : Victron Multiplus Inverter repair: "low battery"
olNick
Posted: 10:01am 12 Mar 2020
Hello  again, Nick here,
Have 2 older Victron Multiplus inverters, 12V/2500VA inverter chargers.
Initially bought to parallel them. Never was able to (the docs wrt  jumper config was wrong, gave up).
So, ok, I have redundancy. The first inverter stopped working after a couple of years, with a low battery led blinking.
Swapped over to the second inverter, and all was good, until recently, where I cooked it during battery maintenance (forgot I left array connected, and it smoked, still beating my self for doing this). A couple of caps at least, blew in the output stage.
Main Question is:
In general, is a "low battery" function implemented?What can I check for this?
Inverter has 3 boards.
The control/logic board has the eeprom with firmware, led indicators and a couple of discrete components that I should be able to check.
The intermediate board has the battery lugs, big dc busbars, fuse, circuit breaker, relays etc, and the 8 pin ic dc-dc? I'll get the ic type later.
The output board with the mosfets and drivers is sandwiched between the 2 toroids and I'd prefer to check that last.
Note: After cooking the second inverter, I swapped the control board the low bat inverter and still got low batt, possibly implying it's not the control board.
Swapped the intermediate board and all leds started blinking :-(
have stopped here,
Victron Greece say buy a new inverter. Victron Netherlands say we only sell, talk to a distributor.
regards,
Nick
PS I wish I knew about your Ozverters, Warpverters etc, 6 months ago.
Arthurl
Posted: 07:46am 12 Apr 2020
Hello Nick,
I have been repairing inverters for quite a while now.
I'm a troubleshooter for industrial and business equipment.
i might be able to repair your Victron.
Please pass on a  message.
Arthurl
olNick
Posted: 06:46pm 12 Apr 2020
Hi Arthur,
Sounds good Arthur. I'm in Crete. Where are you.
Maybe send me a pm with your cell and we can talk.
geia,
Nick
Arthurl
Posted: 04:14am 13 Apr 2020
Hello Nick,
Please check your pm messages.
Arthur
