Local Time 21:49 24 Oct 2026 Privacy Policy
Forum Index : Solar : Inverter Software.
Phil23
Posted: 03:42am 01 Jan 2018
Is anyone familiar with this software?
Wondering a few things, like is it possible to configure it so it shows rolling daily history, instead of from the 1st of the month.
Only been running it since Dec 23rd, & today it starts a new month, so looking back requires generating charts from logs.
Also, I get the impression there may be some sort of standard involved in the data stream & that maybe alternate software might be available.
Very new to this, so don't know a whole lot on this front.
Phil.
Revlac
Posted: 12:40pm 01 Jan 2018
I have only used it for 24hr and it seems to only do it per page.
You can have a look here.
http://forums.aeva.asn.au/viewtopic.php?f=31&t=4332
And never tried this
http://iccsoftware.co.za/
Aaron
Cheers Aaron
Off The Grid
Phil23
Posted: 08:03pm 04 Jan 2018
Would like to know if it will run on a rPi.
I've loaded it on both Ubuntu & my RPi3, I can launch it fine in Ubuntu,
but not able to as yet on the Pi.
Not sure I'm using the right procedure, or if it's even compatible.
It comes in both 32 & 64 bit.
Anyone got any thoughts?
Phil.
Phil23
Posted: 08:19pm 04 Jan 2018
From the manual , which seems common over several inverter brands
Giantpower, in this instance:-
[Quote] Platforms supported by software are listed below:
Ø Windows 2003/XP/Vista/2008 (32bit &x64bit)
Ø Windows 7/8 (32bit& x64bit)
Ø RedHat Linux 8,9
Ø Linux RedHat Enterprise AS3, AS5, AS6(32bit &64bit)
Ø Linux SUSE 10 (32bit &64bit)
Ø Linux Cent OS 5.4 (32bit &64bit)
Ø Ubuntu 8.x,9.x,10.x (32bit &64bit)
Ø Linux Fedora 5
Ø Linux OpenSUSE 11.2 (32bit &64bit)
Ø Linux Debian 5.x, 6.x (32bit &64bit)
Ø Mac OS 10.6(x64bit)
Ø Mac OS 10.7(x64bit)
Ø Mac OS 10.8(x64bit)[/quote]
The Version I received does not have a windows installer & the manual states it's a portable app & just needs dropping in a directory to run.
That all works out fine on Windows.
On the Ubuntu box, same seemed to apply, download the archive, dig out the software folder from a few levels down, then just run the executable.
I get the impression that there my be a different launch procedure required on an rPi.
I'm no Linux Guru by any measure, more a case of running it with training wheels.
Phil.
Edit,
Another link to a different vendor.Edited by Phil23 2018-01-06
